Edit Widget App Builder 3
1117
03-14-2012 11:31 AM
TedCronin
How do you save edits?
I like that you give me the ability to turn on layers for editing, well done and I see that my feature services are now accessible (Currently in SLB only some are, and has been pretty frustrating), the button for Merge is a bit confusing in that it looks like a split, any changes for the buttons chosen, like Split (Cut), seems like a consistent experience for Map users should be employed for the tool icons.
TedCronin
On by default, I see.  So, originally, I created a poly, then cut the poly into two, then selected the two and deleted, but then it seemed like it deleted the two, but brought back the initial edit.  Does this make sense, or expected?
TedCronin
So, I did a bit more testing on this and it works as I have said.  If I create a poly, cut into two, delete the two, I see the original one, then need to delete a second time.  It should just delete once.  If I create a poly, then reshape the poly, then try and delete the reshaped poly, I see the original shape before the reshape then need to delete a second time.  Another process that when needed to be deleted, should happen during the first delete operation rather than having to do two deletes.   One thing though for updates, the browser I am using (Chrome and Firefox) does not seem to refresh updates, or deletes quickly.
Love though that when I add, I can add, then close browser, then reopen browser, then reselect update and then delete.  SLB does not allow this to happen (Not to compare).
