Dynamically add/remove widget icons
749
05-10-2011 06:27 AM
DinaWijewickrema
Is there a way to dynamically add/remove widgets? I have an application which provides functionality based on the User's role. So for an Admin type user, I need to show all widgets/functionality and provide the user the icons for them on the top banner. For Read-Only users, I need to show a smaller set of widgets/functionality and not show any widgets icons the User does not have access to.
Thanks.
Dina
BjornSvensson
Esri Alum
The easiest is probably to use different main configuration files based on their roles, for example:
index.html?config=config_admin.xml
vs
index.html?config=config_readonly.xml
