Dynamic TOC
1390
07-30-2012 01:34 PM
KennyHoran
I have an application with a huge layer tree structure.  A user starts by selecting a location and then the relevant layers are added to the map and the user can browse the TOC to toggle them.
I would like the user to view the TOC from the Layer List widget or the Map Switcher widget, however neither will initialize when configData.opLayers is empty.  As a result the uninitialized TOC will never show my new layers.  So, how can I initialize the TOC in the Map Switcher and Layer List plugins?
Note: Adding an operationallayer in config.xml will initialize both, but that's not ideal.
RhettZufelt
MVP Notable Contributor
As you said, you could add an operational layer with alpha="0.0" and exclude from the TOC.
This would initialize, but would never be visible to the user.
I'm sure there is a more "proper" way to do this, but, this is ESRI afterall, so thought I'd chime in with a potential "work around" 😮
R_
KennyHoran
Aw, play nice!  That did work well though, I hadn't considered excluding my only layer.  That causes the TOCs to initialize and display a blank menu.  I just wish I had a bit more control and with that in mind I have two suggestions for ESRI.
1. Always initialize the TOC and have a configurable default message for when it's blank. -or-
2. Allow the TOC to be initialized on request.
