Do Feature Access require arcSDE geodatabase
4690
08-03-2011 03:16 PM
KellyMontelone
I am trying to use the edit widget, but no layers are editable.  I found that I need to turn on the Feature Access, but that causes the service to not restart.
so, does feature access require arcSDE geodatabase or can a file geodatabase be used?
ChristopherOlsen
Yes, you will need ArcSDE (File GDB will not work), but you also have to need to have Server Standard or Advanced.  Here is the info:
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/What_is_a_fea...
http://www.esri.com/library/brochures/pdfs/arcgis-server-functionality-matrix.pdf
