Display point with action script fails in widget
1714
08-29-2013 05:57 AM
MikeSmith7
I have created a widget and I can not get it to put a SimpleMarkerSymbol at the location (x,y).  The code compiles but myGraphicsLayer.add(myGraphicMarker); is not firing.  I clearly am missing something.
Mike
RobertScheitlin__GISP
Mike,
   A new MapPoint is expecting an x (Number) and a Y (Number) NOT a MapPoint object which is what featureSet.features[0].geometry is returning. Also featureSet.features[0] is a graphic already so why not just add it to the Graphics layer?
var myGraphicMarker:Graphic = new Graphic(new MapPoint(featureSet.features[0].geometry),
                new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
MikeSmith7
I had that very line in as part of my testing, I even hard coded a X and Y value and could not get it to shop up. There is something simple I am missing, but have been banging my head for a while now on this on.
Mike
Code:
<?xml version="1.0" encoding="utf-8"?>
// Written by Micheal W. Smith
// Aug 15, 2013
// This Widget is meant to read the URL, parse for a specific parameter (facility or premise) and a unique id
// The result is zoomed, centered and marked with a point.
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
       xmlns:s="library://ns.adobe.com/flex/spark"
       xmlns:mx="library://ns.adobe.com/flex/mx"
       xmlns:Search="widgets.Search.*"
       xmlns:viewer="com.esri.viewer.*"
       xmlns:esri="http://www.esri.com/2008/ags"
       xmlns:components="com.esri.viewer.components.*"
       x="600" y="300"
       initialize="basewidget_initializeHandler()"
       widgetConfigLoaded="basewidget_widgetConfigLoaded()">
<viewer:states>
  <s:State name="graphicalInput"/>
  <s:State name="textInput"/>
  <s:State name="resultsList"/>
</viewer:states>
<viewer:transitions>
  <s:Transition autoReverse="true" toState="*">
   <s:Fade id="fade"/>
  </s:Transition>
</viewer:transitions>
<fx:Script>
  <![CDATA[
   import com.esri.ags.FeatureSet;
   import com.esri.ags.Graphic;
   import com.esri.ags.geometry.MapPoint;
   import com.esri.ags.layers.GraphicsLayer;
   import com.esri.ags.symbols.PictureMarkerSymbol;
   import com.esri.ags.symbols.Symbol;
   import mx.controls.Alert;
   import mx.events.FlexEvent;
   import mx.rpc.AsyncResponder;
   [Bindable]
   public var UniqueID:String = "000000";
   private var zoomScale:Number = 10000;
   private var graphicsLayer:GraphicsLayer;
   private var resultSymbol:Symbol;
   private function basewidget_initializeHandler():void
   private function basewidget_widgetConfigLoaded():void
    var layer:String =""
    if (ExternalInterface.available)
     // Use JavaScript to get the search string from the current browser location.
     // See http://livedocs.adobe.com/flex/3/langref/flash/external/ExternalInterface.html
     var urlstring:String = ExternalInterface.call("function(){ return document.location.href.toString();}");
     var words:Array;
     if (urlstring && urlstring.length > 0)
      if (urlstring.indexOf("?premise=") > 0)
       layer="premise";
       words=urlstring.split("?premise=");
       UniqueID=words[1];
      else if (urlstring.indexOf("?facility=") > 0)
       layer="facility";
       words=urlstring.split("?facility=");
       UniqueID=words[1];
      if (layer=="premise")
       queryPremise.execute(queryPoint, new AsyncResponder(onResult, onFault));
//       Alert.show("Searching Premise");
      else if (layer=="facility")
       queryFacility.execute(queryPoint, new AsyncResponder(onResult, onFault));
//       Alert.show("Searching Facility");
      function onResult(featureSet:FeatureSet, token:Object = null):void
       if (featureSet.features.length == 0)
        Alert.show("No mapable items found. Please try again.");
       else
        map.scale = zoomScale;
        map.centerAt(featureSet.features[0].geometry as MapPoint);
        import com.esri.ags.SpatialReference;
//        import com.esri.ags.symbols.PictureMarkerSymbol;
        //var myGraphicMarker:Graphic = new Graphic(new MapPoint(featureSet.features[0].geometry),new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
//        var myGraphicMarker:Graphic = new Graphic(new MapPoint(-7033223.1, 5827260.9, new SpatialReference(102100)),
//         new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933));
//         new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 22, 0x009933));
        //myGraphicMarker.toolTip = "Marker added with ActionScript";
        //var myGraphicsLayer:GraphicsLayer
        Alert.show("A");
//       graphicsLayer.add(myGraphicMarker);
          //adding the graphics layer to the map
        //map.addLayer(myGraphicsLayer);
         Alert.show("B");
//         myGraphicsLayer.add(myGraphicMarker);
      function onFault(info:Object, token:Object = null):void
       Alert.show(info.toString());
    else
     Alert.show("interface not accessable");
</fx:Script>
<fx:Declarations>
  <!-- Symbol for Query Result as Point -->
  <esri:SimpleMarkerSymbol id="sfs" alpha="36" color="Black"/>
  <!-- Layer with Premises -->
  <esri:QueryTask id="queryPremise" url="http://atlantis:6080/arcgis/rest/services/SearchTest/MapServer/0"/>
  <esri:QueryTask id="queryFacility" url="http://atlantis:6080/arcgis/rest/services/SearchTest/MapServer/3"/>
  <esri:Query id="queryPoint"
     outSpatialReference="{map.spatialReference}"
     returnGeometry="true"
     text="{UniqueID}">
  </esri:Query>
</fx:Declarations>
</viewer:BaseWidget>
Mike,
   You dis-took the code that I posted as code I wanted you to use when, In the text of my post I tell you that that code is incorrect. I just posted the BAD code to show you where your mistake was.
Here is code that should work:
                        else
                            var myGraphicMarker:Graphic = featureSet.features[0] as Graphic;
                            myGraphicMarker.symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933);
                            var myGraphicsLayer:GraphicsLayer = new GraphicsLayer();
MikeSmith7
Sorry Robert, I misunderstood.  I added the code and I get the same result (lack of a marker).  I put a try and catch around
try
catch
    Alert.show(error.toString());
I get  TypeError: Error #1009
Mike,
   OK Here is a working version of your widget:
// Aug 15, 2013
                   creationComplete="basewidget_widgetConfigLoaded()">
    <fx:Script>
        <![CDATA[
            import com.esri.viewer.ViewerContainer;
            [Bindable]
                var layer:String ="";
                if(ViewerContainer.urlConfigParams.premise != null){
                    layer="premise";
                    UniqueID = ViewerContainer.urlConfigParams.premise;
                if(ViewerContainer.urlConfigParams.facility != null){
                    layer="facility";
                    UniqueID = ViewerContainer.urlConfigParams.ViewerContainer.urlConfigParams.facility;
                    else
                        graphicsLayer = new GraphicsLayer();
                        map.addLayer(graphicsLayer);
    </fx:Script>
    <fx:Declarations>
                    text="{UniqueID}">
        </esri:Query>
    </fx:Declarations>
