Disable popup on mouseover for RS Identify widget only
2310
8
09-09-2011 12:23 PM
NathanEnge
I'm looking for a way to disable the popup that occurs when mouse over identified feature. I just want the datagrid, and find the popup redundant, and it does get in the way of identifying subsequent features underneat the popup...
Thanks
Nathan
PaulGrimes
was a solution ever proposed for this ... I have the same issue, the data grid result is fine, I dont want a popup on the feature but i'd like the graphic outline of the datagrid object shown.  The popup i great if there are not many records but in busy datasets its counter productive.
any ideas how to turn them off for Roberts widget would be really appreciated.
Regards
PaulG
RobertScheitlin__GISP
Guys,
   In the code search for the addEventListener that adds the mouseOverGraphic function and comment them out.
MartynSmith
Guys,
For some reason, this didn't work for me. I commented out the two occurences of the line below, and am still getting the popup on the map when I hover over the result:
idResult.forceScale = identForceScale;
      identifyArrayCollection.addItem(idResult);
      //iGra.addEventListener(MouseEvent.ROLL_OVER, mouseOverGraphic);
      iGra.attributes = idResult;
      graphicsLayer.add(iGra);
Martyn,
  So you are saying that when you hover or the identified graphic that it still pops up an info window...?
MartynSmith
Martyn,
yes...  I have cleared my cache and I'm still getting the the popup over the point when i hover over the entry in the results table
Martyn,
   Yep that is what I thought, you are wanting something different than what these guys were asking for... The code provided here is for disabling the popup when hover over the GRAPHIC on the map not the record in the widget. You need to look at the mouseOverRecord function.
MartynSmith
OK, I seem to have what I wanted after commenting out this line:
   private function mouseOverRecord(event:Event):void
    var idResult:IdResult = ItemRenderer(event.target).data as IdResult;
    clearTimeout(hitimer);
    if (map.extent.containsXY(idResult.point.x, idResult.point.y))
     //hitimer = setTimeout(showHighlight, 300, [idResult]);
    }else{
     hideInfoWindow();
Martyn,
   Support for disabling certain identify buttons and turning off popups is now part of Version 2.5.
