disable enter address feature in 3.1 api
1911
6
01-09-2013 03:49 AM
PeterHoffman
I do not want to use the Enter address line in the new version of flexviewer. How can I prevent it from showing?
GISDev1
Can you send me an actual code sample that shows where to put this?
<?xml version="1.0"?> <configuration>     <search visible="false">         <geocoding>             <locator>http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer</locator>         </geocoding>     </search>     <links>         <link label="About">             <content>                 <![CDATA[                      <p align='center'>                          <img src='assets/images/globe.png'/>                          <br/>                          <b><a href="http://links.esri.com/flexviewer" target='_blank'><font size="+2" color="#FFFF00">ArcGIS Viewer for Flex</font></a></b>                      </p>                 ]]>             </content>         </link>     </links> </configuration>  <!--     For valid HTML tags in Flash applications (that can be used for 'content'), see     http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flashx/textLayout/conversion/TextConverter.html#TEXT_FIELD_HTML_FORMAT --> <!--     See HeaderController widget tag reference at     http://links.esri.com/headercontrollerwidget -->
AnthonyGiles
Honored Contributor
Peter,
In the config file for the header control widget you should be able to set <search visible="false" /> see here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Header_Controller_widget_tags/0...
Regards
Anthony
PeterHoffman
GISDev1
PeterHoffman
That worked, thanks.
AnthonyGiles
Honored Contributor
Peter,
Do not forget to also mark the post as answered to help others search for the answered posts.
Regards
Anthony
GISDev1
Anthony actually answered your question, I just posted the code. I up-voted Anthony's post for answering the question.
