I am facing the problem that the Datum Transformation isn't working from Amersfoort_To_WGS_1984_2008_MBI found that:Name = Amersfoort_To_WGS_1984_2008_MB Wkid = 108457From this pdf: http://resources.arcgis.com/en/help/main/10.1/003r/pdf/geographic_transformations.pdfI use this code to check if there are 3 values in the url, and i look if it is the wkid of RD_NEWif (textualMapPointAttributes.length == 3)
//var wkid:Number = parseFloat(textualMapPointAttributes[2]);
wkid = parseFloat(textualMapPointAttributes[2]);
if(wkid==28992){
rdCheck = true;
And then in the project function this is the code: else
var projectParams:ProjectParameters = new ProjectParameters();
projectParams.geometries = [ geometry ];
trace("input = "+ geometry.spatialReference);
projectParams.outSpatialReference = map.spatialReference;
trace("output = "+ map.spatialReference);
if(rdCheck == true){
trace("rdcheck=true");
var datumTransform: DatumTransform = new DatumTransform();
datumTransform.wkid = 108457;
datumTransform.wkt = "Amersfoort_To_WGS_1984_2008_MB";
projectParams.datumTransform = datumTransform;
projectParams.transformForward = true;
trace("rdcheck=done");
/*projectParams.datumTransform.wkid = 108457;
projectParams.transformForward = true;*/
trace(projectParams.datumTransform);
trace(projectParams.transformForward);
GeometryServiceSingleton.instance.project(
projectParams, new mx.rpc.Responder(projectionSuccessHandler,
projectionFailureHandler));
function projectionSuccessHandler(geometries:Array):void
trace("gelukt "+geometries[0]);
responder.result(geometries[0]);
function projectionFailureHandler(fault:Fault):void
trace("gefaald "+fault);
responder.fault(fault);
This is my output:wkid is 28992input = SpatialReference[wkid=28992]output = SpatialReference[wkid=102100]rdcheck=truerdcheck=done[object DatumTransform]truegefaald [RPC Fault faultString="Error executing project" faultCode="500" faultDetail=""]Anyone know what i am doing wrong?Or are these 3 values the only ones possible from the documentationdatumTransform property
public var datumTransform: DatumTransform
Since : ArcGIS API 3.0 for Flex
The well-known ID or a json object specifying the datum transformation to be applied on the projected geometries. If specified, a value for transformForward parameter must also be specified. If not specified, a search is made through a set of default GeoTransformations. Currently, the following default transformations are used when applicable:
�?�esriSRGeoTransformation_NAD_1927_TO_NAD_1983_NADCON, forward and reverse, WKID=1241
�?�esriSRGeoTransformation_NAD1983_To_WGS1984_1, forward and reverse, WKID=1188
�?�esriSRGeoTransformation_NAD1927_To_WGS1984_4, forward and reverse, WKID=1173
This is an optional property and is only available with ArcGIS 10.1 and higher.
Thanks in advance
