Database Trigger / Simple Geoprocessing Widget - Calculate Fields
2969
02-01-2012 05:07 AM
KarlWilson
What I'm trying to acheive is a way of automatically updating a field once a layer has been created or modified. Specifically, when a user creates a polygon (using the Edit widget) I want a field called "area_ac" to automatically populate with the area of that polygon in acres.
Is there a way of doing this?
I figured that a manual way of updating the "area_ac" field would be to create a very simple Geoprocessing service that uses the Calculate Field tool, and then use the Geoprocessing widget to run it.
I tried setting up an xml config for the Geoprocessing widget, but I don't think it likes the fact that there are no inputs or outputs associated with the service. When I press the submit button on the widget I get an error:
Problem
esriJobFailed
Failed.
Is it possible to run the Geoprocessing widget without inputs or outputs?
GeoprocessingWidget_CalculateAreas.xml
<configuration label="Calculate Areas">
    <taskurl>http://SERVER/ArcGIS/rest/services/GP/viewer/GPServer/Calculate_Acres</taskurl>
    <layerorder></layerorder>
</configuration>
Scottschrader
Kwgis,
Did you find a method to run the calculate field tool on one record via a geoprocessing service?  I would like to build a mobile app that takes user inputs of soil characteristics and then auto populates a field as to the soil capability class and subclass.  Any guides or instructions that you have found to be helpful would be appreciated.
Scott
Problem
esriJobFailed
Failed.
</configuration>
