Data Extract Widget
1082
03-16-2012 10:45 AM
jasonlewis3
Hi
I am working on the data extract widget for the flex 2.5 viewer. It has installed properly and works fine but the output is not what I expected. The tool will not divide or split polygons. For example when I draw the AOI the return will omit any polygons that have been split or divided. I was expecting to get all data in the AOI. Is this the way the tool works? Or is there something I can do to fix this? My .xml file for the widget is below:
<?xml version="1.0" ?>
// CONFIGURATION:
// aioSelectionMethod can be "extent" or "draw."
// dataExtractionService is the url to the GP service.
- <configuration label="Extract incident data">
  <dataextractionservice>http://s2-cor-pangaea:8399/arcgis/rest/services/demo1/GPServer/Extract%20Data%20Task</dataextractionservice>
  <aioselectionmethod>draw</aioselectionmethod>
  </configuration>
    See Data Extract widget tag reference at
    http://links.esri.com/dataextractwidget
by Anonymous User
Not applicable
You are probably running into this:
NIM072621 - Flex Viewer's extract data widget  returns incorrect (or unexpected )output when using the draw rectangle method.
This issue was never resolved and was closed last September. I got around it by eliminating the rectangle tool from the widget.
JustinConner
I cant believe that I spent all afternoon messing with my gp task to get it to work and it was a silly bug that ESRI punted on! Grrr!
JustinConner
Is there a way to remove the rectangle tool without editing the source code?
