css positioning and styling
3821
01-25-2012 03:55 AM
philippschnetzer
This post is a continuation from this post:
http://forums.arcgis.com/threads/48422-embed-webpage-into-the-overview-map
...where Robert shows how to embed a webpage into the index.template.html file.
The issue I am having is the div that contains the link to click ('show') that produces the webpage is displacing the rest of the map downwards.  What would be ideal is being able to place the 'show' link anywhere on the map screen and have it 'floating' over the map while not displacing any of the map.  I looked into some CSS positioning but can't wrap my head around the absolute/relative/static elements and their relation with the rest of the map/divs.  In the attached image (from former post) you can see the white border created by the CSS right above where the esri map starts...
Thank you!
RobertScheitlin__GISP
Phillip,
   So this is what I came up with for the index.template.html:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <!-- saved from url=(0014)about:internet --> <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">         <!--      Smart developers always View Source.           This application was built using Adobe Flex, an open source framework     for building rich Internet applications that get delivered via the     Flash Player or to desktops via Adobe AIR.           Learn more about Flex at http://flex.org      // -->     <head>         <title>${title}</title>         <meta name="google" value="notranslate">                  <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />         <!-- Include CSS to eliminate any default margins/padding and set the height of the html element and               the body element to 100%, because Firefox, or any Gecko based browser, interprets percentage as               the percentage of the height of its parent container, which has to be set explicitly.  Fix for              Firefox 3.6 focus border issues.  Initially, don't display flashContent div so it won't show               if JavaScript disabled.         -->         <style type="text/css" media="screen">              html, body    { height:100%; }             body { margin:0; padding:0; overflow:auto; text-align:center;                     background-color: ${bgcolor}; }                object:focus { outline:none; }             #flashContent { display:none; } /* Added Code */                         #container {                 width: 100%;                 height: 100%;                 position: relative;             }             #flashContent {                 width: 100%;                 height: 100%;                 position: absolute;                 top: 0;                 left: 0;             }             #vessels {                 height: 410px;                 position: absolute;                 padding-top: 5px;                 width: 80%;                 z-index: 10;                 border: 1px solid;                 top: 50px;                 left: 10px;                 background-color: #103c87;             } /* End Added Code */         </style>                  ........................Code truncated to fit.......................................  <!-- Added Code -->                <script language="javascript">          function toggle() {             var ele = document.getElementById("vessels");             if(ele.style.display == "block") {                 ele.style.display = "none";               }else{                 ele.style.display = "block";             }         }          </script> <!-- End Added Code -->     </head>     <body>         <!-- SWFObject's dynamic embed method replaces this alternative HTML content with Flash content when enough               JavaScript and Flash plug-in support is available. The div is initially hidden so that it doesn't show              when JavaScript is disabled.         --> <!- Added/changed Code -->         <div id="container">             <div id="vessels" style="display: none;">                 <script type="text/javascript">                         width='98.5%';        //the width of the embedded map in pixels or percentage                         height=400;         //the height of the embedded map in pixels or percentage                         border=1;           //the width of border around the map. Zero means no border                         notation=false;     //true or false to display or not the vessel icons and options at the left                         shownames=false;    //true or false to display ship names on the map                         latitude=37.4460;   //the latitude of the center of the map in decimal degrees                         longitude=24.9467;  //the longitude of the center of the map in decimal degrees                         zoom=9;             //the zoom level of the map. Use values between 2 and 17                         maptype=3;          //use 0 for Normal map, 1 for Satellite, 2 for Hybrid, 3 for Terrain                         trackvessel=0;      //the MMSI of the vessel to track, if within the range of the system                         fleet='';           //the registered email address of a user-defined fleet to display                         remember=false;     //true or false to remember or not the last position of the map                 </script>                 <script type="text/javascript" src="http://www.marinetraffic.com/ais/embed.js"></script>             </div>             <div id="flashContent">                 <p>                     To view this page ensure that Adobe Flash Player version                      ${version_major}.${version_minor}.${version_revision} or greater is installed.                  </p>                 <script type="text/javascript">                      var pageHost = ((document.location.protocol == "https:") ? "https://" :    "http://");                      document.write("<a href='http://www.adobe.com/go/getflashplayer'><img src='"                                      + pageHost + "www.adobe.com/images/shared/download_buttons/get_flash_player.gif' alt='Get Adobe Flash player' /></a>" );                  </script>              </div>         </div> <!-- End Added/Changed Code -->                                    ............ code truncated to fit................................    </body> </html>
Then as you may notice there is no show hyperlink because you can add that to the HeaderControllerWidget.mxml instead.
//Add this import import flash.external.*;  //Add this new function             private function showFleet():void             {                 ExternalInterface.call("toggle");             } //Find this HGroup and change it:                 <s:HGroup id="linkBox"                           horizontalAlign="right"                           paddingRight="5"                           verticalAlign="middle">                     <s:Label buttonMode="true"                              click="showAbout()"                              styleName="BannerSubtitle"                              text="{labelText}"                              useHandCursor="true"                              verticalAlign="middle"                              visible="{labelVisible == 'true'}"/>                     <s:Label buttonMode="true"                              click="showFleet()"                              styleName="BannerSubtitle"                              text="Toggle Fleet"                              useHandCursor="true"                              verticalAlign="middle"                              visible="true"/>                 </s:HGroup>
Phillip,
philippschnetzer
You are a true guru and saviour!  Thank you so much!  Works perfect!
Philipp,
   I am curious is the site you are working on going to be publicly accessible? I would love to see what you end up with.
philippschnetzer
Robert,
Unfortunately it will be a private site with login required...but I will send you a temp password so you can have a look when it is all done (in a couple of weeks).  There are a lot of your custom/modified components in this site!  Thanks again for all your help!
