Could I get an example for linkprefix?
1183
06-06-2013 07:07 AM
JeffLegato
This should be an easy one.   I think all I need is an example.  Right now I have a field that has a file name and I need to append a link prefix to it.  I got it to work in the pop-up like so:
{APN} {FINDING} <a href="http://server/folder1/folder2/{FILENAME}">PDF Link</a>
When I attempt to configure the Identify widget I see a location for a link prefix but can't find an example of how to enter the necessary prefix.
               <links>                 <link includeinresults="true" field="FILENAME" alias="PDF Link" tooltip="View PDF">                     <linkprefix/>                     <linksuffix/>                     <iconfield/>                     <iconprefix/>                     <iconsuffix/>                 </link>
Any help would be greatly appreciated.
RobertScheitlin__GISP
Jeff,
   Sure it is simple.
<links>                 <link includeinresults="true" field="FILENAME" alias="PDF Link" tooltip="View PDF">                     <linkprefix>http://server/folder1/folder2/</linkprefix>                     <linksuffix/>                     <iconfield/>                     <iconprefix/>                     <iconsuffix/>                 </link>
Jeff,
   Sure it is simple.
JeffLegato
Awesome!  This worked perfectly.
Thanks Robert!
