Copyright text
3341
12-10-2012 12:41 AM
Asta_KristinOladottir
Hi hi,
I want to put copyright text at the bottom of my viewer, just like on this one: http://atlas.lmi.is/kortasja/
Do you know how this is done? I know about the copyright widget but I would prefer it this way.
RobertScheitlin__GISP
Asta Kristin Oladottir,
   The copyright widget does not have an icon... If you follow the readme.txt you should be adding it to the UI elements section of the main config.xml and thus it will not appear in the header controller widget.
   What is it about the one in the link? If it is just the gray background with a border than you can modify the Copyright widget to look like that.
Hi Robert,
there is nothing special about it, the only thing that bothers me about the copyright widget is the icon, but if i simply use the same color for that as the background it becomes kind of invisible.
Thank you, I will try to modify the widget.
Okay, I didn´t knew that, thank you very much
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
