Convert symbol variable
1046
12-04-2012 01:04 PM
jonsumr
I'm trying to convert a symbol type variable to load in an image type variable to appear in my widget, but i'm failing at some point. Does anyone can help? thanks by the way:)
RobertScheitlin__GISP
Jon,
   Sure you just need to use the symbol.createSwatch() method. This gets you a UIComponent and then you just add that as a child to your widget.
Jon,
jonsumr
thanks Robert! this method really solved my problem. 😉
Jon,
   Glad that it worked for you. Don't forget to click the Mark as answer check (Step 1) on this post.
Follow these steps as shown in the below graphic:
