Context menu in 2.3.1 not working
1409
05-11-2011 08:41 AM
MichaelBartlett
In 2.1, I was able to add a context menu by doing the following (see code below).
I moved to 2.3.1 and added the same code to the new MapManager.MXML
Now, the items do not show up when I right click.  Am I forgetting something?
import mx.core.FlexGlobals;
[Bindable]
private var cm:ContextMenu;
Private Function Init(): void
  // Added for Context menu
  var cmi:ContextMenuItem = new ContextMenuItem("Copy Lat, Long to clipboard", true);
  cmi.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, contextMenuItem_menuItemSelect);
  cm = FlexGlobals.topLevelApplication.contextMenu;
  cm.hideBuiltInItems();
  MovieClip(systemManager).contextMenu = cm;
  cm.customItems = [cmi,cmi3];
  cm.addEventListener(ContextMenuEvent.MENU_SELECT, contextMenu_menuSelect);
MehulChoksey
could you try following in MapManager.mxml:
        Alert.noLabel = noLabel;
                if (map.contextMenu)
                    // call contextMenu dynamically so this will compile in AIR
                    if (map.contextMenu["customItems"] is Array)
                        (map.contextMenu["customItems"] as Array).push(menuItem);
                        (map.contextMenu["customItems"] as Array).push(cmi);
                    else if (map.contextMenu["addItem"])
                        map.contextMenu["addItem"](menuItem);
MichaelBartlett
That worked. Thank you very much.
I am guessing that the way I was doing it was adding the context menu of something else besides the map?
Also, would I need to add to this section too?
map.contextMenu["addItem"](cmi); }
MehulChoksey
Yes. Thats correct.
