Configuration file questions!
1674
6
08-05-2013 11:29 AM
weeyeo
Can you create two configuration file (e.g. config.xml(contain print widget) & config1.xml(without print widget)) to run same viewer application?  For example, If user click a button to run print viewer application before loading viewer application then will use config.xml otherwise will use config1.xml.  If so how do you modify the code on index.html file?
Thanks.
RobertScheitlin__GISP
wee y,
   There is no code changes necessary to make this work. You just specify the config file you want to use in the the url:
http://gis.calhouncounty.org/FlexViewer3.4/index.html?config=config-eSearch.xml
This is all explained in the documentation:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Viewer_URL_parameters/01m300000...
wee y,
AnthonyGiles
Honored Contributor
weeyeo
Thank you very much.
MichaelMiller2
Wee,
Check this widget out, I think it may be just what you are looking for.
http://forums.arcgis.com/threads/89949-New-Widget-User-Configuration-Selection-Widget
weeyeo
I found out this morning.  Very useful.  Thanks.
AnthonyGiles
Honored Contributor
Wee,
Sorry I only uploaded it this morning, I meant to pass you the link on this thread but got side tracked. Glad you found it anyway, hope it is of some use.
Regards
Anthony
