ConfigManager Error in Application Builder
1729
07-10-2013 07:33 PM
JosephHinton
I am a new user to the ArcGIS Viewer for Flex - Application Builder, Version 3.4. I have been encountering an error message when working through the Builder. I have no issues when I use the first 3 tabs of the Builder, but when I move to the "Design" or "Preview" tabs, I end up with error messages. The first message reads, "Fault code: InvokeFailed; Fault Info: Error #2148; Fault details: null" The second message reads, "Some error occurred. ExternalInterface doesn't work in Standalone player."
Can anyone point me in the right direction?
Juan_CarlosFranco
This is actually a bug, thanks for reporting this! The Builder shouldn't allow you to set native paths under Web Server Base Folder URL. Could you try going to Settings and changing the Web Server Base Folder URL value to http://localhost/flexviewers ?
I've created an issue for this: https://github.com/Esri/arcgis-viewer-builder-flex/issues/55
JosephHinton
This worked - thank you!
Juan_CarlosFranco
Just wanted to follow up and let you know that this has been fixed for the next release.
