Link absent between feature in pop-up window and feature row in Attribute Table
968
07-24-2013 10:51 PM
OlegLukyanov
When I hit feature on the map pop-up window open but this feature didn't link with this feature row in attribute table. I can see this link in edit mode only. When I select the feature on the map in the edit mode  the row with this feature in attribute table is selected also.
Is it a bug?
Such link work also in Viewer for Silverlight.
BjornSvensson
Esri Alum
Is it a bug?
I don't think it's a bug. When you click a feature on the map to see the popup (what you call "hit feature"), it doesn't really "select" anything. It only outlines the feature so you know which feature the popup is for (note the purple highlight). When you click a feature in the attribute table, you are actually selecting it, which is why the feature on the map gets a yellow-ish color. When you are editing, clicking the feature selects it (so that you can modify geometry etc). Note the yellow selection color when in edit more.
I hope this explains it a bit more...
