Communication between widgets
15371
48
09-28-2010 08:07 AM
DonCaviness
Does anyone know how I would go about communicating between widgets?  I would like to use a button in one widget to call a function in another or change components (label text, visible property, etc) in another widget.  Any help will be appreciated.
SandraPanicucci
Used the below code in an attempt to get searchResultAC from the search widget to use the BMPID in an edit widget right now I am getting the shared data at least as far as the sharedDataUpdated function--at least in debugger my BMPID displays as the title under the variables tab but I don't seem to be able to figure out how to display the shared data in an alert box...which isn't my ultimate goal but would get me closer to figuring out how to use the shared data.
Widget 1
private function widgetCommunication1():void
    addSharedData("your key", shared data(ArrayCollection));
Widget 2
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:viewer="com.esri.viewer.*"
                   initialize="basewidget1_initializeHandler(event)"
    <fx:Script>
        <![CDATA[
            import com.esri.viewer.AppEvent;
            import mx.events.FlexEvent;
            protected function basewidget1_initializeHandler(event:FlexEvent):void
                ViewerContainer.addEventListener(AppEvent.DATA_PUBLISH, sharedDataUpdated);
            private function sharedDataUpdated(event:AppEvent):void
                var data:Object = event.data;
                if (data.key == "my key")
                     // do something..
    </fx:Script>
Hope that helps.
JesseMetcalfe
Guys stucked here...
My sharedDataUpdated () is not getting called 2nd time when my widget is opened.
See Thread -
GaneshAnanthakrishnan
Bob,
   You have to know your widgets Id number. The widgets id is not a string it is a sequential number that is assigned when the widget is created in FlexViewer.
Here is the code:
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.WIDGET_RUN, yourWidgetsID#));
I added a new function to the ViewerContainer.mxml for the purpose of finding a widgets id #
//Add this new variable at the beginning with the other  private and public vars
public var _configData:ConfigData;
//Add this new function
                        public function getWidgetId(widgetLabel:String):Number
    var id:Number;
    for (var i:Number = 0; i < _configData.widgets.length; i++)
     if (_configData.widgets.label == widgetLabel)
      id = _configData.widgets.id;
    return id;
//Add this to the postConfigHandler function
_configData = event.data as ConfigData;
Then you can do something like this
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.WIDGET_RUN, ViewerContainer.getWidgetId("Search")));
Hi Robert,
I am trying to open a search results widget from a submit button on my headercontroller widget as opposed to opening it by clicking an icon in the widget menu(the default method).
Am I correct in my understanding that the above solution will only work if the widget is specified in the config.xml file (which is when the widget id is assigned)?  What if I don't want the widget visible in the menu but I want to open the widget?  How would I reference the widget without the id?
RobertScheitlin__GISP
Ganesh,
   Sounds like you need to go deep into the widgetmanager and look at the onRunWidget method and try and understand how widgets are loaded a individual modules from a url. Good Luck.
ZhujingXia
Any progress for add in widget from the run time? I'd like to add widget2 from widget1. But the widget2 is did not list in the config.xml file. Anyone sould help on this topic?
zhujng
AnthonyKeogh1
Bob,
Here is the code:
    var id:Number;
    return id;
Hi again Robert,    I know this is a fairly old post now but this function would be very useful to me at the minute.
I was wondering how you can call the getWidgetId function the way you are above since the function is not static and there is no instance of ViewerContainer to be able to call the function?
I have added in all of the code above into my ViewerContainer.mxml file and the calls I need into my other file where I want to run the widget but, if I dont make the getWidgetId function static I can't access it and if I do try to make it static I get an "Error #1009: Cannot access a property or method of a null object reference." at line 273: "var wgtContainer:IWidgetContainer = configData.widgetContainers[idx.container].container.obj;" of the WidgetManager.mxml file
Thanks for any help.
Anthony,
All you have to do is call
ViewerContainer.getInstance()
AnthonyKeogh1
I tried both
viewerCon:ViewerContainer = ViewerContainer.getInstace();  // inside init()
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.WIDGET_RUN, viewerCon.getWidgetId("Selection") ) );
AND
ViewerContainer.dispatchEvent(new AppEvent(AppEvent.WIDGET_RUN, ViewerContainer.getInstance().getWidgetId("Selection") ) );
and I recieved the same error. Im probably making a stupid mistake somewhere.
Anthony,
   Try some simple debuging like:
trace(viewerCon.getWidgetId("Selection"));
or
Alert.show(viewerCon.getWidgetId("Selection"));
Is "Selection" the label that you defined for the widget you are after in the main config.xml?
AnthonyKeogh1
Hi Robert, I got it working. Thanks for the help again! Sorry about not replying I have been away the last couple of weeks.
