Communication between widgets
2209
06-02-2014 01:30 AM
SaadiaElaarji
hi,
i'm new in flex, and im working on Webmapping application using flex 4.6, java, and sql server as database, i'm just trying to make a communication between wigdets, i would like to copy each selected item of my combobox in widget1, and show it in the textinput in widget2, i just followed this steps explaind by Robert here http://forums.arcgis.com/threads/13863-Communication-between-widgets?highlight=widget+communication http://forums.arcgis.com/threads/13863-Communication-between-widgets?highlight=widget+communication but no luck, the problem that i'm facing is that i can't call components of the first widget (textinput, button....) from the second widget, they are often underlined !!
at jump you found the change i made,
Widget 1
var layoutArr:ArrayCollection = new ArrayCollection();
   private function widgetCommunication1():void
    addSharedData("Liste des chapitres", layoutArr);
Widget 2
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
       xmlns:s="library://ns.adobe.com/flex/spark"
       xmlns:mx="library://ns.adobe.com/flex/mx"
       xmlns:viewer="com.esri.viewer.*"
       width="638" height="552" creationComplete="application1_applicationCompleteHandler(event)"
       initialize="basewidget1_initializeHandler(event)">
<fx:Script>
  <![CDATA[
                        import com.esri.viewer.AppEvent;
   import mx.events.FlexEvent;
 protected function basewidget1_initializeHandler(event:FlexEvent):void
    ViewerContainer.addEventListener(AppEvent.DATA_PUBLISH, sharedDataUpdated);
 private function sharedDataUpdated(event:AppEvent):void
    var data:Object = event.data;
    if (data.key == "Liste des chapitres")
     dplist.selectedIndex = IntChap.text;
 </fx:Script>
<s:DropDownList id="dplist" x="10" y="10" width="282" height="26" labelField="IntituleChap" dataProvider="{RemoteRapportDao.Selection.lastResult}" change="dplist_changeHandler(event)" ></s:DropDownList>
IntChap wich is on red and bold is the textinput in widget1 , i got it underlined in widget 2, even if i made this communication
any one can tell me what i'm messing ??
any help or code will be appreciated !
RobertScheitlin__GISP
Saadia,
   The principle of widget communication is to pass data (an array collection or object) between widgets, not to allow a component or variable of one widget to be seen and used by another. If you are wanting widget 2 to get the text in the intchap.text then you need to pass that text value in the array collection that is passed from widget 1.
SaadiaElaarji
thank you for your reply, it works now 😉
