Common Tools between Custom Config's
1970
6
09-11-2012 10:40 AM
WarwickAttree
Hi, any ideas on how to have a set of common tools / Widget Group/s to be loaded from a single XML so that this can be shared between a number of custom Config.xml's ?
We have a number of config.xmls for various divisions, and each time a new tool is added or tweaked, then have to manually change all the config files for the new tool.
Would like to call a common tools section from each config file so to lower the maintenance aspect...
Thanks
MikeMartin
You can create a commonwidgets directory and then change the widget xml and swf path to it. For example, I have an apps directory in which each of the FlexViewer apps sit. There is also a commonwidgets directory in the apps directory. Using the eSearch widget as an example, the code in the config file is:
<widget label="Search for HUCs" left="80" top="80"
                icon="../commonassets/images/m_search_right.png"
                config="../commonwidgets/eSearch/eSearchWidget_HUCs.xml"
                url="../commonwidgets/eSearch/eSearchWidget.swf"/>
WarwickAttree
Thanks, but not quite, I need to pull in a Widget group to all the Custom configs, if there are 14 Configs, a bit of a pain to copy & paste the group to 14 different apps...
RobertScheitlin__GISP
Warwick,
   The icon, config, and url are just expecting a url to the file location so instead of using a relative url just use a full url that points to a custom virtual directory on your web server that hosts all your common config files. Seems pretty simple and straight forward, or am I missing something...
WarwickAttree
Robert, yes at a widget level that is true...
As I said, I have 14 different config files for various sections requiring various assortments of layers to be loaded...
If I need to update a Widget group
Eg <widgetgroup label="Tools" icon="assets/images/GeoprocessingTool32.png">
           <widget�?�..1�?�
<widget�?�..2�?�
<widget�?�..3�?� etc
I then need to copy this change to the 14 different config files�?�
I am looking for an Include type statement that can pull in a xml file of the widget group, on the fly.
This would then place the group in the config file and then I would only need to update the widget group in one place�?�
Make sense ?
Thanks
Warwick,
   OK, that makes sense. There is no such capability though. What you are wanting would require some serious reworking of the ConfigManager.
RhettZufelt
MVP Notable Contributor
Have not done exactly this (yet), but it should be pretty simple to have a python script iterate through the list of 14 config files and find the block of text between <widgetcontainer layout="float"> tags and replace it with a the widgetcontainer block from your "template" config file.
Then, whenever you make changes, just run the script (or automate it) and the updates are made in one swoop.
R_
