Color Scheme Change
3226
7
03-05-2013 11:58 AM
MalcolmEchaluce
I don't know how else to title this so please excuse that right off the bat.
I have a flex application that all of a sudden switched up in colors on me.  Please see image of the awful white controls.
[ATTACH=CONFIG]22383[/ATTACH]
Does anybody know which widget, control, xml, etc., this part of the application is for me to take a look at and see why it changed the color on me all of a sudden?  Maybe at one point, I got too clicky or careless and either deleted something or typed something within the line of code for that, but I am having a very difficult time trying to revert back to the blue that it was as shown behind the other widgets on the top menu.  It also shows plain white as the background (and it should be bluish) for the contents of the widgets as well (see image)
[ATTACH=CONFIG]22385[/ATTACH]
Thanks!
by Anonymous User
Not applicable
Original User: rscheitlin
Malcolm,
   What does your main config.xml style elment look like?
    <style>
        <colors>0xffffff,0x103c87,0x359dc6,0x294867,0xffffff</colors>
        <alpha>0.8</alpha>
    </style>
MalcolmEchaluce
Malcolm,
Hello, Robert!
As always, I appreciate your response.  I've checked that particular line of code in my config.xml before and found no problems with it at all.  I thought that I was missing some color then but here's that line of code anyway:
<style>
 <colors>0xFFFFFF,0x0174DF,0x101010,0x00BFFF,0xFFFFFF</colors>
 <alpha>0.8</alpha>
</style>
What do you think?
Thanks!
by Anonymous User
Not applicable
Malcolm,
   Did you make any code changes in the UIManager.as or the default.css? It looks like you changed the ChromeColor some where at a global level.
MalcolmEchaluce
Malcolm,
Robert,
As far as I'm concerned, I have not made any code changes in the UIManager.as.  I even went head and found the default code for the UIManager.as (HERE) and replaced that with what I had and still the problem persists.  As for the defaults.css, nothing had been changed as seen here:
/* CSS file - Standard Stylesheet */
@namespace s "library://ns.adobe.com/flex/spark";
@namespace mx "library://ns.adobe.com/flex/mx";
@namespace esri "http://www.esri.com/2008/ags";
@namespace viewer "com.esri.viewer.*";
@namespace viewerComps "com.esri.viewer.components.*";
@namespace apiComps "com.esri.ags.components.*";
esri|PopUpRenderer
 skinClass: ClassReference("com.esri.viewer.skins.PopUpRendererSkin");
viewer|WidgetTemplate
    background-alpha: 0.8;
    borderStyle: solid;
    borderThickness: 1;
    cornerRadius: 5;
    dropShadowVisible: true;
    horizontalScrollPolicy: off;
    shadowDirection: right;
    shadowDistance: 5;
    skinClass: ClassReference("com.esri.viewer.skins.WidgetTemplateSkin");
viewerComps|TitlebarButton
    skinClass: ClassReference("com.esri.viewer.skins.TitlebarButtonSkin");
.BannerTitle
    padding-bottom: 2;
    padding-top: 4;
.BannerSubtitle
.WidgetTitle
    fontWeight: bold;
s|VScrollBar
    skinClass: ClassReference("com.esri.viewer.skins.VScrollBarSkin");
mx|VScrollBar
    downArrowUpSkin: Embed(source="assets/images/arrow_down.png");
    downArrowOverSkin: Embed(source="assets/images/arrow_down.png");
    downArrowDownSkin: Embed(source="assets/images/arrow_down.png");
    upArrowUpSkin: Embed(source="assets/images/arrow_up.png");
    upArrowOverSkin: Embed(source="assets/images/arrow_up.png");
    upArrowDownSkin: Embed(source="assets/images/arrow_up.png");
    thumbDownSkin: Embed(source="assets/images/thumb.png");
    thumbUpSkin: Embed(source="assets/images/thumb.png");
    thumbOverSkin: Embed(source="assets/images/thumb.png");
    trackSkin: Embed(source="assets/images/track.png");
s|HScrollBar
    skinClass: ClassReference("com.esri.viewer.skins.HScrollBarSkin");
mx|HScrollBar
global
 content-background-alpha: 1.0;
by Anonymous User
Not applicable
Malcolm,
   I am not sure where to point you from here. All the things I had you check are the likely culprits, short of that I really don't know.
You could try and use a different color scheme like the black and gold and see if it changes anything:
<style>
    <colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>
    <alpha>0.8</alpha>
</style>
MalcolmEchaluce
Malcolm,
<style>
    <alpha>0.8</alpha>
</style>
Thanks, Robert. I have changed it before and it didn't fix the problem.  I appreciate all your advice though.
by Anonymous User
Not applicable
Original User: rzufelt
Malcolm,
It looks like maybe you are using an older viewer?  What version is it?  any chance you have upgraded some skins or something from a newer version?
R_
