close popups
1442
09-10-2012 05:00 PM
AHay
hi anyone know how to close a popup ( with code We are using 2.4 still)
we have an app that adds layers  based on a users choice of project from a table
when the user clicks the button to select a new project i want any pop us they have open to close
i thought this should be easy
i use PopUpmanger.removePopup(map) on the click event of choose another
but this does nothing
RobertScheitlin__GISP
A Hay,
   The Viewers popup are not controlled through the PopUpManager so as you have figured out you can not use the PopUpManager. It is as simple as:
map.infoWindow.hide();
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
A Hay,
AHay
Thank you
so simple
