Chart Widget
2049
03-10-2011 11:46 AM
JimWelsh
I know the chart widget is not being updated or supported, but I was wondering if someone can help me out.  Is there documentation anywhere on what the xml fields are for?
I ask this because I have the chart widget working and it charts the correct numbers.  But... the summaryfield is throwing me for a loop.  It is displaying a number much larger than what it should.  Is it supposed to display the value of the field I enter or is it adding numbers up or something else?
Also, is the xcolumnfield used for the pie chart or just the bar graph?  (which I haven't figured out how to activate in 2.2)
Thanks.
RobertScheitlin__GISP
Jim,
   The summary field does sum the field specified taking the values of all the features that are selected and the values of that field from those features and sums them together. As far as how to get to the bar chart just click on a portion of the pie to inspect the details of that particular portion of the pie.
