Chart Widget Color Question
1630
04-04-2011 01:31 PM
AlexSanders
Does anyone know how to change the color of the pop up window that appears when you mouse over a field from black to another color.  My text is a darker grey and it blends in with the black.
Alex Sanders
Texas General Land Office
MehulChoksey
try adding following in UIManager.as
if (numberOfStyleColors > 4)
            var cssStyleDeclarationChartDataTips:CSSStyleDeclaration = new CSSStyleDeclaration();
            cssStyleDeclarationChartDataTips.setStyle("backgroundColor", backgroundColor);
            topLevelStyleManager.setStyleDeclaration("mx.charts.chartClasses.DataTip", cssStyleDeclarationChartDataTips, false);
before this line:
 var cssStyleDeclarationModal:CSSStyleDeclaration = topLevelStyleManager.getStyleDeclaration("global")
AlexSanders
Mehul,
That worked perfectly, thank you for your help.
Alex Sanders
MattiasEkström
I Have the same problem, but the solution doesn't work for me. Using the suggested code results in an error:
1120: Access of undefined property numberOfStyleColors.
I'm currently still in Flexviewer 2.1, maybe that's the reason?
RobertScheitlin__GISP
Mattias,
  That is your issue. Try this if statement instead.
if (configData.styleColors.length > 4)
MattiasEkström
Thanks, that worked for me.
