channel.security.error on arcgis 10.1 server
2360
09-05-2012 06:44 AM
PeterHoffman
I am developing for a new VM server windows 2008 r2 with ArcGIS server 10.1. All of the machines are in the same domain. The rest services are on another 10.1 server. The application displays properly on my PC but I get the following error messages when I install it on the test server:
Live Layer Layer failed to load:Fault code:Channel.security.error
fault info: Security accessing url
Fault details:Destination:DefaultHTTP
It looks like a crossdomain problem but I can see the rest services from the testserver.
Thanks.
PeterHoffman
Yep, it needed a crossdomain.xml file. Must be a netappliance issue.
PeterHoffman
