Channel.Security.Error from ArcGIS Sever MapManager
22720
35
01-27-2012 08:04 AM
ThomasMcCracken
Hi everyone,
I get an error window when I open my Flex Viewer application that says:
"Layername layer failed to load: Fault code: Channel.Security.Error
Fault info: Security error accessing url
Fault details:  Destination:  DefaultHTTP
The crossdomain.xml is on the GIS and web server and is correct.  In fact, another
GIS Server with the exact same crossdomain.xml brings in the service in the app just fine.  I tested using both SOAP and REST services and get the same result.  I also get the same error from my local web client on my machine rather than the web server so I'm not sure what's going on.  Any suggestions?
Thomas McCracken
GIS Analyst
Georgia Power Company
ThomasMcCracken
After setting Secure='false' for both domain and headers my services are now working in the viewer perfectly.
RobertScheitlin__GISP
Thomas,
   Can you actually get the crossdomain.xml file to display in your web browser when you use it's url in the address bar?
http://YourServer/crosdomain.xml
ThomasMcCracken
Yes, it shows up when I type in the URL.
Thomas,
   So does the ArcGIS Server have security enabled?
ThomasMcCracken
No, the security is disabled as well.  I can't make any sense of it!
TimTaylor2
Have you found a solution to this, I am running into the same problem even after setting the crossdomain security policy to false
ThomasMcCracken
No, I haven't found a solution yet.  I'm setting up ArcGIS Server on another server with IT now to see what results we get.  We tested with another internal server before with someone else's services and they came in fine.  We also tried using mxd's and msd's and got the same result with both.  SOAP/REST didn't matter either.  If I figure anything out I'll post it, but as of now I haven't a clue.
Thomas
So guys,
  When you type the REST URL of one of your map services in the address bar of your browser does it bring up the REST Service Directory?
i.e. http://gislap134/ArcGIS/rest/services/highway/MapServer (do not use local host and you can not mix and match IP addresses and machine names).
ThomasMcCracken
Yes, I can get to the rest endpoint and the services work within ArcMap/Catalog.
Thomas,
  actually the fact that it works in ArcMap and ArcCatalog has little relevance as they both use SOAP and not the REST endpoint.
So you are not using localhost and you are not specifying the IP address in one place and the server name in another, such as IP in the crossdomain and servername in the url for the layer?
