Change Size of Overview Map Widget
4446
18
12-28-2012 05:51 AM
MichaelVolz
Esteemed Contributor
Is it possible to change the size of the compiled overview map widget in the Flex Viewer application?
GISDev1
Here's your requested widget. I created a version for both V3.0 and V3.1
Overview Map Custom Size :
http://www.arcgis.com/home/item.html?id=56bb06a6340f46aaa8b7d99c75b893e2
MichaelVolz
Thank you very much GISDev01 for this useful enhancement.
Is there any chance you can add the uncompiled code to the page where the compiled code is located?
GISDev1
I plan to add it to my github account soon. Same username on there.
MichaelVolz
How would I access this location to download the uncompiled code?
GISDev1
Here is the uncompiled code:
https://github.com/GISDev01/OverviewMapWidgetCustomSize
If you make further modifications, I just ask that you share the changes with everyone if possible.
MichaelVolz
Thanks again for the uncompiled code.
I was reviewing the code and I do not understand how the .mxml file knows how to retrieve the data from the .xml file.
if (configXML)
                    overviewMap.configXML = configXML;
This seems like where the mxml file is trying to access the xml, but how does it know to look for OverviewMapWidget.xml if it is not explicitly passed in the variable configXML?
GISDev1
if (configXML)
I actually used to wonder the same thing a while back.
That is part of Esri's Flex API. The joy of using good API's is they basically do the work for you. For each widget, it looks for a .xml that is designated in the config.xml. You pass the variables just using the identifier *.configXML
MichaelVolz
Thanks for the explanation.
Do you know where I would find the original source code for the OverViewMap widget that is part of the out-of-the-box build?
GISDev1
Sure, right here:
https://github.com/Esri/arcgis-viewer-flex
