Change media container size in Pop Up Window
3981
12
08-29-2011 10:35 AM
CarrieTropasso1
I would like to change the media container size in the popup window for Flex Viewer 2.4 so that there are no gaps around the top and bottom of my image - see attached image (I want to remove the gaps so that the blue border is tight against the image).  Where do I access this information to change this setting?
WillHughes1
Robert,
One more questions regarding label rotation.
I added labelRotation="45" to the
<mx:horizontalAxisRenderers> tag
and then compiled, however the labels are not rotated. What am I missing?  Thanks.  Will
<mx:ColumnChart
id="columnChart"left="1" right="1" top="1" bottom="1"dataTipFunction="columnSeriesDataTipFunction"showDataTips="true">
<mx:series>
<mx:ColumnSeries id="columnSeries" yField="value"/>
</mx:series>
<mx:horizontalAxis>
<mx:CategoryAxis id="columnAxis" categoryField="name"/>
</mx:horizontalAxis>
<mx:AxisRenderer axis="{columnAxis}" showLabels="true" labelRotation="45"/>
</mx:horizontalAxisRenderers>
</mx:ColumnChart>
RobertScheitlin__GISP
Will,
   I dealt with this MANY versions ago of the API and Flex SDK and the only way I could be label rotated back then was to embed the font in the main index.mxml. That was back when you had to embed fonts in a Flex App if you wanted them rotated though.
AtanasRusev
Hi ;),
trying to resolve the same question I just do the simplest and it worked:
in PopUpRendererSkin.mxml change this: (I wanted bigger popup...)
<s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:esri="http://www.esri.com/2008/ags"
xmlns:supportClasses="com.esri.ags.skins.supportClasses.*"
  width="350"
maxHeight="400"
preinitialize="skin_preinitializeHandler(event)">
and then, because I dont want the square box and empty spaces:
in PopUpMediaBrowserSkin.mxml :
private function imageOrChartGroup_resizeHandler(event:ResizeEvent):void
  imageOrChartGroup.height = imageOrChartGroup.width -100 ; // Hacko make it not square
so depends on what you want as size - but for me it was the easiest custom way
Best Regards!
