Change LayerList Dynamic Srvc on/off from edit widget
548
07-02-2012 09:33 AM
SaugatJoshi
Hi all,
In the native Edit widget when we select the checkbox on/off the same is reflected to the corresponding feature service layer in the LAyer List Widget. How can I connect the same control to the corresponding MapService Layer in LayerList widget. Eg:
In Layer list I have
[]Dimension---Feature Service
[]Dimensions----Map Service
In Edit Widget
[]Dimension
In Edit widget when I check the []Dimension, corresponding []Dimension is checked in LayerList widget. However I also want []Dimensions to be checked. How can I achieve this? Really appreciate you comments.
Thanks.
Saugat
