Cannot perform query on first search.
770
08-03-2012 06:54 AM
ChristopherBlinn1
All,
I'm working on the eSearch widget (last version for 2.5 viewer), and I think some of my custom code has caused an issue with the widget.
Run the application from Flash Builder 4.6 and the very first query I try to run from the eSearch widget returns an error that it cannot perform the query.  However, if I hit search again, it will conduct the query.
In addition, if I run the application, I cannot use the Graphical search until I run a Text search query.  You try to select a geometry to select and it will not allow you to select a graphic.  However, like I said, once a successful query runs from the Text search, the tool works as it should.
Please see attached.
Chris B.
ChristopherBlinn1
The issue seems to be resolved once the .swf is compiled.
ChristopherBlinn1
In addition, I tried doing a Graphical search using a graphic drawn by the eDraw widget, and 0 results were returned.
No error, just 0 feature found.
Any help is appreciated!
Chris B.
ChristopherBlinn1
