Cannot load a tiled map service
4311
02-21-2013 02:55 PM
by Anonymous User
Not applicable
Original User: xintaoliu
I am using Flex Builder 4.6 + flex viewer 3.0 + agslib-3.1.swc.
When I use the config.xml file ([ATTACH=CONFIG]22064[/ATTACH]) to load the included tiled map service, it is okay. But, when I replace the layer in the basemaps by using the below tiled map service on my own server:
<layer label="Demographics" type="tiled" visible="true" alpha="1.0"
         url="http://141.117.248.106:6080/arcgis/rest/services/IceWaterLand/MapServer">
</layer>
I always got an error as shown below:
[ATTACH=CONFIG]22063[/ATTACH]
I got stuck for some time. Any of your comments and suggestions are highly expected! Thanks!
by Anonymous User
Not applicable
Try setting these two attributes on the map tag to false:
wraparound180="false" addarcgisbasemaps="false"
This is an issue in 3.1 when the base map layer is not geographic or web mercator.
By dpaddock at http://forums.arcgis.com/threads/73799-Issues-with-3.1-Flex-Viewer-and-App-Builder?highlight=access+...
by Anonymous User
Not applicable
Original User: rzufelt
Not sure, but I'm thinking it might be related to your spatial reference.  All the "working" basemaps that I have used have a wkid in there, not the entire SR string.  However, i don't see a WKID for the SR you are using.
I think it might be related as I can load any of you layers as an operational layer, it is only when you try to load as a basemap.
if I try to load your layer with the config you supplied, I get the error that you get.  However, if I change the extent of the map to match the extent of your IceWaterLand layer, it will load and display just fine.
It is not until I try to zoom in past the LOD3 that I get an error, and it is related to the geometry utils.
TypeError: Error #1009: Cannot access a property or method of a null object reference.
 at com.esri.ags.geometry::Extent/http://www.esri.com/2008/ags/internal::getParts()
 at com.esri.ags.geometry::GeomUtils$/intersects()
 at com.esri.ags.symbols.supportClasses::PolygonDrawer/draw()
 at com.esri.ags.symbols::SimpleFillSymbol/draw()
 at com.esri.ags::Graphic/http://www.esri.com/2008/ags/internal::drawWithSymbol()
 at com.esri.ags::Graphic/commitProperties()
 at mx.core::UIComponent/validateProperties()
 at mx.managers::LayoutManager/validateProperties()
 at mx.managers::LayoutManager/doPhasedInstantiation()
 at mx.managers::LayoutManager/doPhasedInstantiationCallback()
So, thought maybe your cache is corrupt, but I can load it as an operational layer and it loads/zooms just fine.
Sorry I'm not more help, but in case this helps you figure it out,
R_
XintaoLiu
Thanks for your reply! It is informative and helpful. However, I don't think the cached map service is corrupt. If you test this link: http://141.117.248.106:6080/arcgis/rest/services/IceWaterLand/MapServer?f=jsapi ,this map service loads/zooms just fine.
Regarding the spatial reference, the reason why it is a SR string, because it is a customized spatial reference. Therefore, these is no WKID to use.
by Anonymous User
Not applicable
by Anonymous User
Not applicable
I always have my wraparound and esribasemaps set to false.
Your test map service link finally times out with an internal server error.
R_
TiagoRibeiro1
Many thanks!!!! 🙂 This saved my day.
