Can you copy text input from one Geocoder text to another one?
1278
03-13-2014 08:02 AM
MayJeff
I create two Geocoder compenent. One use my own geocode locator service and another one use ESRI.  See my attachment file.  I want to use a text I type in header controller widget and show it on search widget so won't need to retype it. Just like copy and paste it manually.  Is there possible?
Hope someone can help.
Thanks.
RobertScheitlin__GISP
May Jeff,
   In the HeaderControllerWidget.mxml make these changes:
            protected function singleLineSearch_keyUpHandler(event:KeyboardEvent):void             {                 addSharedData("esriGeocoderText", new ArrayCollection([singleLineSearch.geocoder.text]));             }                 <components:GeocoderComponent id="singleLineSearch"                                               width="230" height="28"                                               includeInLayout="false"                                               visible="false"                                               keyUp="singleLineSearch_keyUpHandler(event)"/>
and here is an example widget that listens for that data and adds the text you type in the main geocoder to a new geocoder:
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"                    xmlns:s="library://ns.adobe.com/flex/spark"                    xmlns:mx="library://ns.adobe.com/flex/mx"                    xmlns:esri="http://www.esri.com/2008/ags"                    xmlns:viewer="com.esri.viewer.*"                    xmlns:components="com.esri.viewer.components.*"                    widgetConfigLoaded="init()">     <fx:Script>         <![CDATA[             import mx.collections.ArrayCollection;             import com.esri.viewer.utils.Hashtable;             import com.esri.viewer.AppEvent;                          private function sharedDataUpdated(event:AppEvent):void             {                 if (event.data.key == "esriGeocoderText")                 {                     if (event.data.collection[0]){                         singleLineSearch.geocoder.text = event.data.collection[0];                     }                 }             }                          private function sharedDataUpdated2(event:AppEvent):void             {                 var dataTable:Hashtable = event.data as Hashtable;                 if (dataTable.containsKey("esriGeocoderText"))                 {                     var recAC:ArrayCollection = dataTable.find("esriGeocoderText") as ArrayCollection;                     for (var i:Number = 0; i < recAC.length; i++)                     {                         singleLineSearch.geocoder.text = recAC;                     }                     dataTable.remove("esriGeocoderText");                 }else if(dataTable.containsKey("Deactivate_DrawTool")){                     setMapAction(null, null, null, null);                 }             }                          private function init():void             {                 if (configXML){                     var geocoderXML:XML = configXML.geocoder[0] || configXML.search[0];                                          const shouldEnableGeocoder:Boolean = geocoderXML && (geocoderXML.@visible[0] != "false");                     if (shouldEnableGeocoder)                     {                         singleLineSearch.hostBaseWidget = this;                         singleLineSearch.includeInLayout = true;                         singleLineSearch.visible = true;                     }                 }                 AppEvent.addListener(AppEvent.DATA_PUBLISH, sharedDataUpdated);                 AppEvent.addListener(AppEvent.DATA_SENT, sharedDataUpdated2);                 fetchSharedData();             }                      ]]>     </fx:Script>          <viewer:WidgetTemplate id="wTemplate"                            width="275" height="120">         <components:GeocoderComponent id="singleLineSearch"                                        width="230" height="28"                                       includeInLayout="false"                                       visible="false"/>     </viewer:WidgetTemplate> </viewer:BaseWidget>
MayJeff
How about use my own geocode locator serviceto search first, if no result match your textinput then use ESRI geocorder to search?
I try to modify geocoder component to perform this function.  Hope someone got some ideas?
May Jeff,
MayJeff
Thank you very much Robert.  You're so awesome:)
