Can the documentation for 3.0 still be accessed?
1079
02-05-2013 07:29 AM
DougBrowning
MVP Esteemed Contributor
I can only get 2.5 or 3.1, 3.0 does not seem to be anywhere.
We have a 2.5 widget that uses locateTask.addressToLocations(myAddress, myOutFields, new AsyncResponder(onResult, onFault));
and this is totally different in 3.1 due to changes in 10.1.
But I want to see if this is also different in 3.0 or not.  That might seal the deal on if we are going to use 3.0 or 3.1.
Thanks.
RobertScheitlin__GISP
Doug,
Right from the docs (which tell you what API release they changed in).
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/tasks/Locator.html
addressesToLocations    ()    method
public function addressesToLocations(parameters:AddressToLocationsParameters, responder:IResponder = null):AsyncToken
Since :     ArcGIS API 3.0 for Flex
Sends a request to the ArcGIS REST geocode resource to find locations for a set of addresses specified in the address parameter. On completion, the addressesToLocationsComplete event is fired and the optional callback responder is invoked. Requires ArcGIS 10.1 or higher.
Parameters
    parameters:AddressToLocationsParameters ??? The AddressToLocationsParameters object contains the addresses.
    responder:IResponder (default = null) ??? The responder to call on result or fault. The result function will be given an array of AddressCandidate instances.
Returns
    AsyncToken ???
See also
com.esri.ags.tasks.supportClasses.AddressCandidate
Doug,
Parameters
Returns
    AsyncToken ???
See also
