Can the BufferDistance widget be extended?
1420
04-15-2013 10:15 AM
ShaningYu
Honored Contributor
The BufferDistance widget (V3.2) is only for Point buffering.  I wonder if the author, Mr. Robert Scheitlin, can extend the tool for general use with the functions for line and polygon's buffering, just using the components in eSearch-master (
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e).  Thanks.
ShaningYu
Honored Contributor
Customized the BufferDistanceWidget with the components in the DrawWidget.  Now the Buffer tool works well for Line and Polygon also.
MichaelVolz
Esteemed Contributor
Can you not get this functionality from the Enhanced Search Widget already?
ShaningYu
Honored Contributor
I am working on the customization now.  But if there is an one for general, it will be great.
ShaningYu
Honored Contributor
JanetRogers
I am looking for a Buffer Widget like the one you have mentioned here.  Have you published it anywhere?
FrancisSenyah
Hi Shaning - Apologies if i've mis-read, have you customised Robert's Point Buffer Widget to use line or polygon?  if so where can I find the build?  Regards, Francis.
