Can Flex Viewer 1.x access ArcGIS Server 10.1?
1217
12-05-2012 11:39 AM
KevinKimm
Hi, my organization's Flex Viewer is still based on Flex Viewer 1.x with Flex SDK 3.4. It has been working fine with ArcGIS Server 9.3 and 10.
We are still trying to migrate the Viewer to the latest Flex Viewer 3 version, but have not completed yet for some reasons, and I am wondering if the current Viewer on 1.x can run on map services published by ArcGIS Server 10.1. Does anyone know about this?
BjornSvensson
Esri Alum
...I am wondering if the current Viewer on 1.x can run on map services published by ArcGIS Server 10.1.
The 1.x does not work with Tiled 10.1 services, but it will work fine with ArcGISDynamicMapServiceLayer and ArcGISImageServiceLayer running on 10.1 servers.
BjornSvensson
Esri Alum
KevinKimm
Thanks for the reply. I am just curious why 1.x cannot read 10.1 tiled map service. Can you tell me that?
BjornSvensson
Esri Alum
Clarification: Version 1.0-1.2 does not work with TILED ArcGIS 10.1 Services.  Version 1.3 and onwards are fine to use.
It fails in older versions because ArcGIS 10.1 is not backwards-compatible with tiled mapping requests that send in the .png extension as part of the URL.  We used to do this before version 1.3 API.
Accepted by 10.0, but not 10.1
http://myserver/arcgis/rest/services/MyService/MapServer/tile/2/1/1.png
As of 1.3, we just ask for tiles as
The workaround for 1.0-1.2 is to either upgrade to 1.3 or later, or a developer could extend the layer, override the getTileURL() method, call "super" and then strip off the extension.
