Call a function on eSearch from a popup button click
1456
09-18-2013 05:54 AM
MayJeff
I created an extra button on popup infowindow (PopUpRendererSkin.mxml).  How do you call a getLocateGra() function on eSearch when user click a button on popup infowindow instead of click the icon on eSearch widget?
Thanks.
RobertScheitlin__GISP
May Jeff,
   If that widget has to be opened first then it is not ready to receive the getLocateGra function request. You will have to figure out a way to delay the getLocateGra function request until the widget is opened and ready. This is not something simple that I have time to provide an example for but it can be accomplished by understanding the widget communication model. Here is a link to my Widget Communication Explained.pdf
May Jeff,
   Put this code in the buttons click handler. Of course you will have to change the getLocateGra function from private to public for this to work:
                var id:Number = ViewerContainer.getInstance().widgetManager.getWidgetId("Enhanced Search");
                var bWidget2:IBaseWidget;
                bWidget2 = ViewerContainer.getInstance().widgetManager.getWidget(id, false);
                var eSearch:* = bWidget2;
                eSearch.getLocateGra();
MayJeff
Thank you so much for the code but I have some questions about the click button handler on my popup infowindow.
When first click, it will open esearch widget but you have to click again in order to call getLocateGra() function to highlight a polygon. Is possible when you click the button, it will call getLocateGra() function for highlighting a polygon?
May Jeff,
MayJeff
Thank you very much.
