Cache not displaying
2368
10-09-2011 11:06 AM
MattShetzer
I�??ve built a new cached landgrid to display in my flex project (SFV 2.4), and it is not displaying correctly.   All looks ok on the server, and I�??ve matched the LOD�??s as in my flex project.  When I go into the server, and look in the arcgisserver/arcgiscache/SupprtingServices_PLSS_SupportingData_Cache all the data is generated correctly and displays with landgrid data in the tiled PNG�??s.
The cache service is located at:
http://server.petro-fs.com:8887/ArcGIS/rest/services/SupportingServices/PLSS_SupportingData_Cache/Ma...
and I�??m calling it from my config.sys with:
<layer label="PLSS Cache" type="tiled" visible="true" alpha=".7" url="http://server.petro-fs.com:8887/ArcGIS/rest/services/SupportingServices/PLSS_SupportingData_Cache/Ma..."/>
I�??m not sure what I�??m missing, and I�??ve created the cache as exploded.
For testing purposes, I  created a second service, being dynamic, with the same data (copied the MXD and created a new service).  Everything is working in the dynamic service as It should.
I�??m calling the dynamic service with:
<layer label="PLSS Dynamic" type="dynamic" visible="false" alpha=".7" url="http://server.petro-fs.com:8887/ArcGIS/rest/services/SupportingServices/PLSS_SupportingData/MapServe..."/>
And the service is located at:
I�??m stumped as why the cached service is not displaying in my project !!!!  Thank in advance for your help !
Matt Shetzer
BjornSvensson
Esri Alum
I think the most likely issues would be related to either LODs or serving the tiles.
LODs:
Are you sure they are exactly the same as whatever base map you are starting up your flex viewer application with?
If you try adding it as the first base map, does it work as expected?
Tile serving:
If you go to the service directory, http://server.petro-fs.com:8887/ArcG...ache/MapServer and click
"View In ArcGIS JavaScript" does it work?  What if you try "View In ArcGIS.com Map"?
MattShetzer
Bjorn,
Thank you for the fast reply.  The cache is not displaying in ArcGIS either.  As for the LOD, I copied them from my project and they are as follows.
Thanks again for your help !!!
Matt
Tile Info:
    Height: 256
    Width: 256
    DPI: 96
    Levels of Detail: (# Levels: 11)
        Level ID: 0 [Start Tile, End Tile]
            Resolution: 0.00137483009346774
            Scale: 577790.554289
        Level ID: 1 [Start Tile, End Tile]
            Resolution: 0.00068741504673268
            Scale: 288895.277144
        Level ID: 2 [Start Tile, End Tile]
            Resolution: 0.00034370752336634
            Scale: 144447.638572
        Level ID: 3 [Start Tile, End Tile]
            Resolution: 0.00017185376168317
            Scale: 72223.819286
        Level ID: 4 [Start Tile, End Tile]
            Resolution: 8.5926880841585E-05
            Scale: 36111.909643
        Level ID: 5 [Start Tile, End Tile]
            Resolution: 4.29634404219822E-05
            Scale: 18055.954822
        Level ID: 6 [Start Tile, End Tile]
            Resolution: 2.14817202109911E-05
            Scale: 9027.977411
        Level ID: 7 [Start Tile, End Tile]
            Resolution: 1.07408601043058E-05
            Scale: 4513.988705
        Level ID: 8 [Start Tile, End Tile]
            Resolution: 5.37043005334264E-06
            Scale: 2256.994353
        Level ID: 9 [Start Tile, End Tile]
            Resolution: 2.68521502548159E-06
            Scale: 1128.497176
        Level ID: 10 [Start Tile, End Tile]
            Resolution: 1.3426075127408E-06
            Scale: 564.248588
    Format: PNG8
    Compression Quality: 0
    Origin:
        X: -20037508.342789
        Y: 20037508.342789
    Spatial Reference: 4269
Intial Extent:
    XMin: -106.205755623061
    YMin: 38.7236031136306
    XMax: -104.897052069855
    YMax: 39.2744483364803
Full Extent:
    XMin: -116.077141830899
    YMin: 31.3281858223016
    XMax: -94.5872622324659
    YMax: 49.0010996820002
Units: esriDecimalDegrees
Supported Image Format Types: PNG32,PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ,BMP
Document Info:
    Title: twn
    Author: mshetzer
    Comments:
    Subject:
    Category:
    Keywords:
    AntialiasingMode: None
    TextAntialiasingMode: Force
