BUG : widget position with vertical layout in FlexViewer
3387
01-04-2011 01:07 AM
carinestolz
Dear all,
I found a little bug in the FlexViewer when using the Widget Container with vertical layout.
It can easily be reproduced.
- Open the ArcGis Flexviewer samples page :
http://help.arcgis.com/en/webapps/flexviewer/samples/index.html.
- Click on the "Widget container layouts" / "Vertical WidgetContainer" sample.
- Open one widget.
- Click the widget container "collapsed" Button to hide the widget container.
- Open another widget.
The widget container appears but at a wrong position (cf. attachment).
Has anyone encountered this problem ? Is there any code to fix this error ?
Many thanks for your help !
Carine
JasonNielsen
I have ran into this problem when i was using the vertical alignment. It seems to be effected by the map switcher. Since i kept getting so many different results of widget placement varying from the right side of the screen, i decided to drop the vertical alignment and left it at "float" for the widgets. I defined the default locations of all of the widgets when they opened using a "x" and a "y" value.
MehulChoksey
Thanks for reporting this bug. This will be fixed in the next release of the viewer.
carinestolz
Many thanks for your reply !
For information, in which period the next version will be released ?
Best regards,
Carine
BjornSvensson
Esri Alum
This bug has been fixed for the 2.4 release that is planned for July 2011.
