Basemap - Imagery with Labels
1358
5
08-16-2012 05:44 AM
PeterHoffman
I am trying to find out how the new ArcGIS viewer for Flex does the Basemap selection of 9 different basemaps.
Where is the code located in the new 3.0 version?
Thanks!
RobertScheitlin__GISP
Peter,
  Just to clarify you do not have to be using portal. It is just a way that the Viewer team has chosen to make it easier on the configure'r to add all available basemaps from ArcGIS Online with just a simple attribute on the map tag. You can manually override these basemaps by entering them as you did in previous versions in the main config.xml.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Peter,
   The base maps are retrieved from the ArcGIS Portal when you use the new addarcgisbasemaps="true" on the map tag in the main config.xml.
PeterHoffman
ok, thanks, we are just starting to use portal
Peter,
PeterHoffman
OK, thanks again.
Peter,
   Don't forget the most important step. Marking the thread as answered.
Don't forget to click the Mark as answer check on this post (Step one in the graphic).
