Banner width
2404
17
03-21-2011 10:44 AM
CindyKamigaki
I'd like to widen the banner in Flex Viewer and cannot find reference to banners in the codes provided in the flexviewer folder. I've found reference to banner.mxml within the ArcGIS forums, but that seems to apply to API for Flex.  Any clarity would be greatly appreciated.
RobertScheitlin__GISP
Charles,
    That is correct if you are using the Flex Viewer source code than you can not adjust the header height.
charlessaenz
If I move to the API would it still be restricted or am I able to have more free reign on customization?
Charles,
   If you want to start from scratch and are a semi experienced developer than yes use the API. The Flex Viewer is a great tool for the non-developer as it gives them a great point to begin with. If you are considering using the API than you you would need to use some compiler like Flash Builder 4 or Flash Develop, etc. If you are going to do that then why not use the Flex Viewer source code?
charlessaenz
Hmmm...I think I'm comfortable with just Viewer hahaha, not really ready to move onto the API yet. Thank You though with all of your help.
SamuelLingeman
You'll want to take a look at the HeaderControllerWidget.mxml file in the /src/widgets/HeaderController/ directory. Specifically, the contents of "headerGroup"
<s:Group id="headerGroup"
        width="100%" height="85">
   <!-- basic structure is an hbox with
        logoIcon: a logo (if specified)
        titleGroup: the title on top of the subtitle
        widgetBox: icons for all widgets specified in main configuration file
        linkBox: "link buttons" for all links specified in main configuration file
<mx:HBox id="headerContent"
That should get you started.
Cheers,
K
Hi Robert, I implemented this and my header it now taller (height increased), but predicatably, the map is now slightly under the header, any ideas on how to fix this?
Samuel,
   Whatever height you ended up changing you banner to is the number you need to set the top attribute of your map to in the main config.xml.
<map wraparound180="true" initialextent="-9598200 3968200 -9500400 4026200"  top="40" >
SamuelLingeman
Samuel,
I'm sure you get told this all the time, but I'm not sure what most of us inexperienced people would do without your help and patience.  Any ideas on moving the navigation widget down a bit, it now spills over into the header.  Perhaps I should stick with a stock header.
Samuel,
   The navigation widget has a top property as well:
<widget left="10" top="50" config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/>
