Autocomplete search box
8411
36
01-12-2011 04:13 AM
LemvigKommune
Hi.
I've just uploaded my AutocompleteSearch widget to arcgis.com - but
I would like it to iterate through multible url's and add the features in each url to the dropdownbox, but i can't get it to do just that.
If anybody has any idea as to how i could solve this, i'll be happy to hear about it.
Thanks
Mads Gren
ReneRubalcava
Esri Frequent Contributor
I have a widget with some functionality that can load services via a config.xml that might help.
http://www.arcgis.com/home/item.html?id=ca9e4de998714d07a6bdc59ededa0efc
 * Takes URL for a ArcGIS Server Rest directory and
 * will attempt to extract the SiteMap.
 * @param directory
protected function loadServices(servername:String):void
 var service:HTTPService = new HTTPService();
 var sitemap:String = "/ArcGIS/rest/services/?f=sitemap";
 var url:String = "http://" + servername + sitemap;
 service.url = url;
 service.resultFormat = "e4x";
 var token:AsyncToken = service.send();
 token.addResponder(new AsyncResponder(onServiceResults_handler, onFault_handler));
 * Handles the results of accessing the SiteMap.
 * @param event
 * @param token
protected function onServiceResults_handler(event:ResultEvent, token:Object = null):void
 var xml:XML = event.result as XML;
 var xmlColl:XMLListCollection = new XMLListCollection(xml.children());
 var list:Array = [];
 var qn:QName = new QName(sitemapNS, "loc");
 var sxml:XML;
 for each (sxml in xmlColl)
  var url:String = sxml[qn].text();
  var tmp:Array = url.split("/");
  var i:uint = tmp.length;
  if (tmp[i-1] == "MapServer")
   var item:ServiceItem = new ServiceItem();
   item.serverType = tmp[i-1];
   item.name = tmp[i-2];
   item.url = url;
   list.push(item);
   findServiceDetails(item);
 list.sortOn("name");
 dataList = new ArrayList(list);
 vUrls = new Vector.<String>(list.length);
 servicesList.dataProvider = dataList;
 * Parses <code>ServiceItem</code> object url to find layer details
 * in service REST.
 * @param item
protected function findServiceDetails(item:ServiceItem):void
 var jsonurl:String = "?f=json&pretty=false";
 var url:String = item.url + jsonurl;
 var srv:HTTPService = new HTTPService();
 srv.url = url;
 srv.resultFormat = "text";
 var token:AsyncToken = srv.send();
 token.addResponder(new mx.rpc.Responder(onJSONResult_handler, onFault_handler));
 function onJSONResult_handler(event:ResultEvent):void {
  var data:String = event.result.toString();
  // this regex replace can be used to make parsing the JSON faster.
  // It removes spaces, but it will mess up service description.
  //data = data.replace( /\s/g, '' );
  var details:Object = JSON.decode(data);
  item.description = details["serviceDescription"];
  if (!details["singleFusedMapCache"])
   item.type = DYNAMIC;
  else
   item.type = TILED;
This will get you as far as loading the individual URL's for each service in a server, like "sampleserver1.arcgisonline.com", then you can create a layers using the URL and pull out the Layer info via layerInfos. I have a function for another tool that does just that.
 * Will find all the items that make up a given map service layer.
 * @param lyr
protected function findLayerDetails(lyr:Layer):void
 if (layers)
  layers.removeAll();
 layers = new ArrayList();
 var layerInfos:Array;
 layerIDSet = null;
 layerIDSet = {};
 if (lyr is ArcGISDynamicMapServiceLayer)
  layerInfos = ArcGISDynamicMapServiceLayer(lyr).layerInfos;
 else if (lyr is ArcGISTiledMapServiceLayer)
  layerInfos = ArcGISTiledMapServiceLayer(lyr).layerInfos;
 else if (lyr is FeatureLayer) {
  var lyrId:int = FeatureLayer(lyr).layerDetails.id;
  var lyrName:String = FeatureLayer(lyr).layerDetails.name;
  layerIDSet[lyrName] = lyrId;
  layers.addItem(lyrName);
 if (layerInfos)
  var info:LayerInfo;
  for each (info in layerInfos)
   layerIDSet[info.name] = info.id;
   layers.addItem(info.name);
LemvigKommune
Thanks Rene
But there must be a simpler way beside using httpservices.
The thing i'm looking for is a way to iterate over a actionscript query, with different layerURL's and get it into an array.
But if nothing else comes up, i'll look at your code.
Mads
ReneRubalcava
If you set up your xml config file to let you know the Layer type, "dynamic", "tiled", etc, you can iterate through your list, create layers, then iterate through the layers to get the layerinfos.
LemvigKommune
Hi again
I can almost see that, but i don't want more layers, all I want is the data from a single row, and the graphics so that i can use it as a searchbox
we are using it for our adresssPoints, but I would like to get the parcelID and the graphics from another services as well and put that into the dropdownlist, so that when my coworkers are starting to type, it sorts out the list for them, and when they hit enter it will pan and zoom to their selection.
philippschnetzer
Mads
Nice. Works very well.  Very configurable as well!  To improve the widget it would be nice to have it ignore null values in a table....and also to be able to see the letters you type into the search box.  With those two additions it would be absolutely perfect for me!
Again - good job!
- and perhaps also a clear graphics button...
xanderm
Is this widget affected by the maximum number of records returned by server (500)? Im not seeing all of my results in the drop down.
LemvigKommune
Hi Phillip
The thing about not seeing what you are typeing into the searchbox, is a problem i don't understand, have you tried my testsite ??
I'll look at the thing about ignore Null values and a clearbutton - thanks for the ideas....
Hi Xander - yes the widget is affected by the max. number in the service - and i can see that i have only told about this on the arcgis.com site, not in the info.txt file in the zip-file, sorry - i'll correct this soon - thanks.
LemvigKommune
Hi Philip
with the help from Robert S, the widget now iterater over multiple layers, and exclude null-values.
and the clear-button is added...
see arcgis.com
Mads
Mads
Again - good job!
PedroGarcia
Hi Phillip
I think that problem is because the backgroundcolor of searchbox is the same than text color (using for example Black Gold style colors, see attached image). Is it feasible that the searchbox background color uses the background color defined in style tag?
Concerning to the problem with the widget is affected by the maximum number of records returned by server, is there any workaround to solve this? (because my addressesPoints are thousands points).
Regards,
   Pedro.
