authenticated data extraction services?
4082
17
01-28-2011 09:27 AM
JonFisher
I have an anonymous Data Extraction task up and running, and am calling it from FlexViewer 2.2 with the DataExtract widget with no trouble. However, in addition to this task, I want a separate authenticated task that will include sensitive data. My hope was that I can use tokens just like when I connect to secure map services via the viewer, but when I set <dataextractionservice> to https://<mysecureserverpath>/rest/services/TNC_internal/core_data_extract_auth/GPServer?token=<mytoken>
and try to call it via the viewer it doesn't work. I'm using the same token I use to connect to the secure map services (which are in the same folder as the secure GP service), and I'm accessing it via the same server / identifier.
Has anyone else tried this, either successfully or unsuccessfully?
DasaPaddock
Firefox doesn't send the referer header unless it's sending a POST request. Is you're token secured by referer or IP?
JonFisher
By referrer. So you're saying the only way to get it to work with Firefox is to use a token secure by IP? Will it still work in other browsers?
DasaPaddock
The tasks automatically switch to using a POST when a token is present. Can you use a tool like HttpFox to verify whether the requests are using POST or GET?
JonFisher
Yes, according to firebug they appear to still be using GET, e.g. using the map link I posted above, the map is requesting:
https://maps.tnc.org/ecadpubprodanon/rest/services/testextract_auth/GPServer/Extract%20Data%20Task?t... which results in an invalid token message. I see that to display the map layers POST requests are used, but not for the data extraction GP service.
DasaPaddock
Try these changes to the DataExtractWidget.mxml file.
1. Make this change since Flash won't POST an empty body:
gpService.send();
to:
gpService.send({ forceFlashPOST: true });
2. Add method="POST" like this:
<mx:HTTPService id="gpService"
                        fault="gpService_faultHandler(event)"
                        method="POST"
                        result="onJSONLoad(event)"
                        resultFormat="text"/>
JonFisher
Thanks, Dasa, that worked! Will these enhancements make it into the next release of the FlexViewer?
shay-geo
All,
Does any one know, how to connect to secured services using Flex Viewer 2.2?
In previous releases, there was a sample on connecting to secured services by adding <proxy> tag into config.xml page.
We have a proxy.aspx with proxy.xml page (which has rest services urls and authentication)
http://help.arcgis.com/en/webapi/flex/help/index.html#arcgis_server/secured_services.htm#
With ESRI sample, there was no proxy tag either in config.xml page. So i was wondering, if anyone did anything special to connect to secured dynamic and cached services.
Shail
DineshKumar1
We are Providing a genuine data extraction services and following this techniques,
  • Extract data from databases
  •     Querying various databases
  •     Digging out important data across numerous databases and formats
  •     Updated information about competitors' services/products, pricing strategy and the latest offers they provide
  •     Extract data from websites, forums, blogs, etc. to review consumers' reviews and opinions
If you want to get more information please search "Informatics Outsourcing"
