Attribute Table Widget - Change Size
1989
6
01-27-2013 08:23 PM
ShaunWeston
I'm trying to change the size of this widget, but doesn't seem to be working from the config using this:
<widgetcontainer paneltype="bottom" initialstate="open" height="250">
<widget label="Attribute Table" config="widgets/AttributeTable/AttributeTableWidget.xml" url="widgets/AttributeTable/AttributeTableWidget.swf"/>
</widgetcontainer>
If I change the height to 100, it doesn't change the size of the widget?
ShaunWeston
Thanks for pointing me in the right direction.
I am using a panel so I had to change the panel height value, which I found in WidgetManager.mxml
It's set to 250.
                        if (ctn.panelType == "bottom")                         {                             bottomContainerVisible = ctn.initialState == "collapsed" ? false : true;                               bcSize = ctn.size ? ctn.size : 250;                             bottomContainer = getBottomContainer(bcSize, bottomContainerVisible);                             bottomContainer.addEventListener(ResizeEvent.RESIZE, handleBottomContainerResize);                             bottomContainer.gap = 2;                             bcOrder = containerCount;                         }
RobertScheitlin__GISP
Shaun,
   The AttributeWidget is hard coded for a height of 300 if you are not using it in a panel.
            private function basewidget_initializeHandler():void
                if (isPartOfPanel) // if widget is part of "left", "right" or "bottom" panel
                    this.percentWidth = this.percentHeight = 100;
                    wTemplate.percentWidth = wTemplate.percentHeight = 100;
                else
                    wTemplate.width = map.width - map.width / 100 - Number(this.left);
                    wTemplate.minWidth = 800;
                    wTemplate.height = wTemplate.minHeight = 300;
Also changing a individual widgets size would involve adding a height and width to the actual widget tag:
    <widget label="Attribute Table" height="400" config="widgets/AttributeTable/AttributeTableWidget.xml" url="widgets/AttributeTable/AttributeTableWidget.swf"/>
</widgetcontainer>
ShaunWeston
It's set to 250.
AnthonyGiles
Honored Contributor
Instead of using height use size:
<widgetcontainer paneltype="bottom" initialstate="open" size="250">
This works without the need to change the source code.
Regards
Anthony
DavidBoiano
Regards
Anthony
Hi Anthony,
I just wanted to comment since there was no confirmation by checkmark that your response was also correct.  I was looking to change the size of my attribute table and stumbled upon this thread--it seems to me your way is the easiest solution.  I was able to change the size of my attribute table panel by using the "size" property instead of "height".
Thanks again!
David
xanderm
Is similar to changing the height of the actual widget inside of a left panel? This is what I am trying to do... I can't seem to gte the adjustment made though the mxml:
                    wTemplate.percentWidth = wTemplate.percentHeight = 150;
                else
                    wTemplate.width = 290;
                    wTemplate.height = 240;
                    wTemplate.minWidth = 210
                    wTemplate.minHeight = 160;
DavidBoiano
Xander,
I would guess it is not working here:
I don't think you can set a width/height as a percent value over 100. Hope this helps.
David
