Attachment Relate Info Window Widget - Fault Error
931
01-09-2013 04:41 AM
JohnLucotch
I was curious if anybody was facing a similar issue.  When I click on the relate table button within the PopUp I can see all the related table possibilities.  I then proceed to click on the related table I want.  If I go back and click on the same related table I get a fault error.  Any help would be greatly appreciated.
JohnLucotch
I was curious if anybody had a run into this issue? I click on the relate and the datagrid opens.  I click on the close button which closes the datagrid popup.  I re select the relates and when I select the desired table it gives me a fault error.
Thanks
