ArcGIS Viewer for Flex - Horizontal Layout
5048
03-27-2015 03:46 AM
SaurabhGupta5
Hello All,
I am using arcgis viewer for flex 3.6 and 'horizontal ' layout for widget container in config.xml. I want to set a property where i can able to resize or detach the widget from horizontal layout. I am preferring horizontal layout because it is aligning the widget in a good way but unable to resize the widgets.
Please suggest.
Regards
Saurabh
SaurabhGupta5
I have found the solution for this one and too very simple.
src-widgets-WidgetContainer-WidgetContainer.mxml
private function setWidgetLayout(layout:String):void
make settings true for isDraggable and isResizeable
Regards
SaurabhGupta5
Hello All Flex Users,
Have anyone done anything on above request. I am still struggling to get it done for one of my client. Please help me with some resolution. Would greatly appreciate the efforts.
Regards
SaurabhGupta5
hi robert,
please help , i think you are having a good hands on flex viewer framework. please suggest some location where i can make changes.
thanks and regards
RobertScheitlin__GISP
Saurabh,
   I am not developing in Flex anymore as this is a language that has reached mature status and is no longer to be updated by esri. I would recommend that you begin migrating your apps away from the Flex Viewer and over to the Web AppBuilder. I will not be investing any time in the flex viewer anymore.
SaurabhGupta5
Hi Robert,
That is our client next plan at least not for now. Anyways , thanks for all
your support in ArcGIS Viewer for Flex. Will look forward for you in ESRI
API's for javascript
Regards
On Wed, Jul 15, 2015 at 9:42 PM, Robert Scheitlin, GISP <[email protected]>
SaurabhGupta5
Regards
