ArcGIS Viewer 3.0 Prerelease for Flex released March 19, 2012
6875
28
03-19-2012 09:15 PM
BjornSvensson
Esri Alum
The new Viewer community site:
resourcesbeta.arcgis.com/en/communities/flex-viewer/
What's new in ArcGIS Viewer 3.0 Prerelease for Flex
http://resourcesbeta.arcgis.com/en/help/flex-viewer/concepts/index.html#/What_s_new_in_3_0_Prereleas...
Note that the URLs have changed slightly from the 3.0 beta.  We will remove those pages later this week.
DasaPaddock
I recommend leaving the project compiler settings to "Use minimum version required by the Flex SDK". You only need to change this if you need to require the user to have a newer version than the minimum for the SDK you're using.
Are you able to run the Viewer at?
http://resourcesbeta.arcgis.com/en/help/flex-viewer/live/index.html
JeffreyUtter
OK, I changed to the Minimum SDK, still get the Flash Player Window message as mentioned above.
To answer your second question, Yes, in IE- 8, Firefox-11, and Chrome-17
DasaPaddock
Try installing the 11.2 debug player from:
http://www.adobe.com/support/flashplayer/downloads.html#fp11
JeffreyUtter
OK, I downloaded and installed the first Windows debugger listed at http://www.adobe.com/support/flashplayer/downloads.html#fp11
I ran the app, it works in IE and Chrome, but not in Firefox, still telling me "This content requires Adobe Flash Player 11.2. Would you like to install it now?"
Not sure why a debugger would let it run........thoughts?
DasaPaddock
It shouldn't require a debug player to run, but you'll want a debug player for development.
The first download under Windows is for IE only. Chrome uses it's own bundled player. The second download is for non-IE browsers.
What does Firefox show at:
https://www.adobe.com/software/flash/about/
JeffreyUtter
OK
Firefox, from your link, is showing 11.0.1.60 installed
JeffreyUtter
OK, I have it working. I downloaded and installed the non-ie debugger, and it now works on Firefox.
Thanks for all your help.
JeffreyUtter
OK, another question. It says for FV 3.0 "Support secure ArcGIS Server where users will automatically be prompted to log in as needed."
Can someone direct me on the How to's to implement this?
Thanks.
BjornSvensson
Esri Alum
OK, another question...
In general, it is usually better to start a new forum thread if you have another question 🙂
Having separate threads for separate questions makes it easier for people to search and find answers to questions that might already have been answered. It also gives people a chance to get "credit" for answering each question..
