ArcGis version for Flex 3 SDK ?
5551
7
04-15-2015 08:08 AM
AhmedAtif
Hi, is there a version for Flex 3 SDK ? specifically 3.6A that comes with Flash builder 4?
I googled it and all what I found is flex 4 using the spark components only.
Thanks
RobertScheitlin__GISP
Ahmed,
   Are you looking for the Adobe Flex SDK or the Esri Flex API?
AhmedAtif
I'm looking for Esri Flex API that works with Adobe Flex SDK v3.6A all, the
current ESRI flex downloads are for Adobe Flex 4 SDK only.
thanks for the quick reply.
On Wed, Apr 15, 2015 at 8:14 AM, Robert Scheitlin, GISP <[email protected]>
Ahmed,
  If I remember correctly the Flex 2.5 API is what you are looking for then.
AhmedAtif
Unfortunately, as per the below link:
  • In version 2.4 of the Viewer, Adobe Flex 4.1 SDK is the minimum SDK version to compile with.
ArcGIS Viewer for Flex
also I checked the code you sent me and it requires Flex 4 SDK as well otherwise I get lots of compilation errors. also if I decided to use a version lower than v2.5 will it have the openstreetroad support ? (probably not)
do you recommend going lower than v2.5 or it is going to be a waste of time?
Ahmed,
  Yes I would not recommend using such an old Flex API version, but if you must then here is the Flex 2.3 API:
AhmedAtif
thank you for your help, just out of curiosity, how did you get that old version; I looked for it a lot but no luck finding that repository. can you please let me know what is the repository URL in case I needed older versions?
Ahmed,
   I have been in the Flex world for many years so that file was from my personal catalog.
