ArcGIS 10.1 Flex Feature Set GP parameters
723
07-10-2013 08:18 AM
MichaelEdelson
Hello, I'm trying to create a Mailout notification tool where the end-user can pick a parcel or parcels using either a point, line, or polygon from the "Feature Set" parameter type.  The selected parcel(s) are then used to buffer and clip the selected parcels to get the owner information to be used with MailMerge (most of you have probably seen this a thousand times.) Anyway, I have the tool working great except for one thing.  The line and polygon selection tools work perfectly, no issues. But when I use the Point selection tool no records are returned, but if I use the Point selection tool again (without clearing the widget) the Point selection tool works fine and returns the values as expected.  So my question is this:  why is my Point select tool not be recognized until after my 2nd click?
I hope this makes sense and if it's helpful I can add some screenshoots or XML code for someone to look at...
Thank you,
Mike
