Annotation Placement not being retained in map services
1694
06-19-2012 06:37 AM
ChristinaGnadinger
I've been looking on the forums but have yet to find an answer to this. I am hoping that someone can help.
At a certain level we have options to turn on pipe details within our Flex application. In doing this we have discovered that the placement / sizing / spacing of the original annotation is not being retained. Checking the MXD the annotation looks as it should but the map service or beyond seems to be where the issue is. I've tried switching from tiled to dynamic to see if that was the trigger but that did not make a difference.
I'm attaching two screen shots. One showing how it looks in the MXD and the other is how it looks on the web app (the image with the overrunning labels). The map services are referencing MSDs if that makes a difference or not.
Any ideas on this or things I could try for troubleshooting?
As always thank you for any considerations and responses to this!
AnthonyGiles
Honored Contributor
Christina,
Are you using the Maplex engine to create your labels, if so I dont think they are supported by server. Have you tried creating an annotation class for your labels?
Regards
Anthony
by Anonymous User
Not applicable
Original User: cgnadinger
These are drawing from annotation and not as labels. I still have yet to find a work around or fix for this. 😞
